Front passenger window
Old Mar 10, 2008 | 02:12 AM
suveer's Avatar
Default Front passenger window
Hi All,
My disco,1997 300tdi left side front passenger window seems to have gone wrong. The switch works but the glass does not seem to be fixed on the channel. You can manualy push the glass up with your hand but not down.What would be the common things to look for.
Many thanks
suveer
Old Mar 10, 2008 | 08:44 AM
bookerbr's Avatar
Default RE: Front passenger window
Most likely it is the window regulator. I have replace two on my 00 Disco. You will have to take off the door panel to verify. Both of mine regulators had a disc roller that broke, they are made of plastic and slide back and forth when you put the window up and down. I found a replacement from a Land Rover parts guys on ebay for around 60 Dollars. Hope this helps.
Brian
Old Mar 11, 2008 | 04:38 AM
suveer's Avatar
thanks very much
caleb
Aug 14, 2009 12:07 PM
roverohio
May 22, 2009 11:17 PM
bcolins
Oct 2, 2008 12:36 PM
jwood700
Apr 17, 2008 07:03 PM
bobbydazzla
Apr 2, 2008 07:42 PM
