Front & Rear HVAC vents - 1 question & 1 issue
Ok, my 01 D2 (that I just recently bought) has great heat when the fan is set to blow at full speed (on highest setting) but the incremental blower settings don't do anything. So, I think there are 5 or 6 levels (dashes on the display when you hit the fan button) to turn it up and down, but I only have air/heat blowing (hard) through the front vents when it's on full blast. All of the lesser settings barely have anything coming out, and do not change the velocity of the air coming out until it's up all the way. Thoughts?
Also, and maybe a dumb question, but do the ceiling vents (for back seat riders) blow heat, or only a/c? In mine, it only blows air (cold) when I click the a/c button on the ceiling control...otherwise it does not blow anything at all. I figured maybe it's just "rear a/c" for the summer time, but figured that would be a waste of a rear air system if heat wasn't available as well. Thank you for your replies in advance.
ssblast20
11-27-2014 10:02 PM
leowiz
12-28-2012 07:53 AM
