FRONT SQUEEKING/VIRBRATION
Old May 13, 2007 | 01:13 AM
TXSALTY's Avatar
7th Gear
Default FRONT SQUEEKING/VIRBRATION
Well, I've been reading all coments pertaining to the front axle and driveshafts and it seems I might be having to rebuild or get new driveshafts. I have a 2000 disco 2 with 95k on the clock, when I accelerate by either slamming it or regular acceleration I get a sqeeking noise, at about 10 to 35 or 45 mph while accelerating it vibrates rather hard until I take my foot off and all is normal. If anyone can point me to a good place to get parts I'd appreciate it, Thanks!!!
Old May 13, 2007 | 07:45 AM
StevenDiscoII's Avatar
Default RE: FRONT SQUEEKING/VIRBRATION
What is the condition of you tires? Reason I am asking, the original Wrangler HP tires were notorious,for causing vibration as you described when the are towards the end of life cycle (besides being extremely noisy), which is anything in excess of 30K miles, doing just 4 tire rotation.Mine original firs setdid that. Then, the second set did the same after about 42K miles with 5 tire rotation method. Finally, the third set I installed were MichelinsXPC 4X4, which have been proving themselves a much better choice.
Old May 13, 2007 | 07:50 AM
At your mileage, your drive shafts are ready for some attention.
Do you have a rear rotoflex at the rear diff, is it starting to crack, how often do you lube your u-joints, have the front u-joints at the t/case been replaced yet and have you ever installed and lubed the slip shafts on both drive shafts?
Mike
Old May 24, 2007 | 12:06 AM
TXSALTY's Avatar
7th Gear
MY TIRES ARE IN TIP TOP CONDITION, HAD THE TIRE FOLKS CHECK THEM OUT, MICHELIN XPC 4X4. TODAY I HAD THE DAY OFF AND DECIDED TO TAKE A LOOK DOWN THERE. NEEDLESS TO SAY, THERE WAS 1 U-JOINT THAT WAS BROKEN AND THE OTHER WAS VERY DRY, SO UP WENT THE TRUCK AND OFF CAME THE FRONT DRIVESHAFT. I READ JUST ABOUT ALL I COULD FIND ON DOUBLE CARDAN JOINTS AND STARTED TAKING OFF THE U-JOINTS. WENT AHEAD AND BOUGHT GREASABLE SPICER JOINTS (2), A NEEDLE GREASE ATTACHMENT, AND SOME GREASE FOR THE GUN. LOW AND BEHOLD WHEN THE LAST JOINT CAME OFF, ABOUT 3 LITTLE ROLLER BEARINGS, SMALLER THAN THE ONES ON THE JOINT CAPS, WERE STUCK INSIDE WHERE THE SPRING IS. NOW MY QUESTION IS THIS... ARE THEY PART OF SOMETHING THAT WAS BROKEN OR DO THEY BELONG ON THE INNER WALL OF THE BALL SWIVEL? UP TO THIS POINT I'M QUITE LOST, I TOOK THE LIBERTY OF TAKING A FEW SNAPSHOTS, IF THERE IS ANYBODY OUTHERE WHO COULD GIVE ME SOME INSIGHT, I'D APPRECIATE IT. - THANKS
[IMG]local://upfiles/3002/E4C4FF04D80943ED8A1D0C7B75444143.jpg[/IMG]
[IMG]local://upfiles/3002/E01ADA8C28E34E67BA1455B120B314FF.jpg[/IMG]
[IMG]local://upfiles/3002/2160CDACD64A43579CF383ACA18F9F63.jpg[/IMG]
[IMG]local://upfiles/3002/80CF69363611439EB8F18DBA241E09AF.jpg[/IMG]
Old May 25, 2007 | 03:58 PM
TXSALTY's Avatar
7th Gear
OK, I'VE NARROWED IT DOWN TO THE NEEDLE BEARINGS IN THE DOUBLE CARDAN SLIP JOINT. DOES ANYONE HAVE OR KNOW OF A PLACE WHERE I CAN BUY THOSE NEEDLE BEARINGS???
Old May 25, 2007 | 04:59 PM
Usually you have to buy the centering ball kit that is made by the same company that made your u-joints.
Have you replaced your u-joints with servicable units, if so go back to where you bought the u-joints and see if they have the kits.
Mike
Old May 26, 2007 | 11:57 PM
TXSALTY's Avatar
7th Gear
DEFINITLEY SO, I WENT AHEAD AND BOUGHT THE 3 U-JOINTS FOR THE FRONT SHAFT, ALL 3 ARE GREASABLE. ... THANKS !!
kman35ca
May 2, 2012 06:00 PM
TheUninformedOwner
Apr 16, 2009 02:46 PM
treho54
Oct 19, 2008 04:28 PM
bcolins
Oct 2, 2008 12:36 PM
ragejb
Apr 9, 2007 09:23 PM
