Whinning/squeeking when ideling ans parked
Old Apr 8, 2007 | 06:08 PM
ragejb's Avatar
Default Whinning/squeeking when ideling ans parked
I have a '95 Disco with 88k miles, for the past few months it has been making a whinning or squeeking sound while sitting at stop lights or parked. I believe it is the alternater pulley or the ideler pulley making this noise. When they go out do they generally whine or squeel like that? Has anyone had this problem before?
It also squeeks when you turn off the engine.
Old Apr 8, 2007 | 09:21 PM
Default RE: Whinning/squeeking when ideling ans parked
You could have a bad belt or bearing. You are going to need to pull the belts off and check to see whwrw the noise is coming from.
Mike
Old Apr 8, 2007 | 11:30 PM
lowill's Avatar
same problem cant figure it out. new belt and the alternator is new. have to check the pulleys though. noise is annoying huh?
Old Apr 9, 2007 | 09:23 PM
lowill's Avatar
Hey mike is changing the idler pully simple on a 98 disco. Also heard that people used this part from a astro van? If so I change it out this weekend. Also what bearings are you talking about?
RoverDan(99)
Mar 2, 2012 07:12 PM
ajmille
Dec 3, 2011 11:08 AM
TheUninformedOwner
Apr 16, 2009 02:46 PM
TXSALTY
May 26, 2007 11:57 PM
Airwolf1
Nov 14, 2006 10:10 AM
