Front sunroof problem
Old Mar 20, 2008 | 12:48 PM
herblatham's Avatar
Default RE: Front sunroof problem
I would think it's the sunroof motor, my 98 disco is doing the same thing, and my ecu has both front and back sunroof wires coming out of it, which would make me think that's not it; and i alsoswapped the switches and the back one still workedproving that it wasn't the switches.What's worse with mine is that it's not closed all the way, and every time it rains hard, it leaks a little, just haven't gotten a chance to replace the motor yet.
Old Mar 20, 2008 | 12:59 PM
ryant06's Avatar
ORIGINAL: herblatham
That sucks man, thats for the info.
Old Mar 20, 2008 | 01:05 PM
Urban Panzer's Avatar
Hi, It could also be the connections on the front motor are corroded due to the usual leaky sunroofs on Disco 1 and 2 's
Its easy enough to check it out, all you need to remove is the screws holding the plastic storage / trim above your head, theres about 8 or 10 in total, there is also 1 screw behind the trim plate thats near the rear veiw mirror,disconnect thesunroof switches etc.
once thats out of the way you can easily see whats going on up there. it will enable you to disconnect the sunroof plug and check theres voltage at the plug. You can also use an "allen key / hex wrench" to manually wind the roof open / closed to check its not "physically" siezed.
Old Mar 20, 2008 | 02:03 PM
ryant06's Avatar
ORIGINAL: Urban Panzer
Thanks, that is really great information, it just might save me from loading my RAVE CD
BigRed98
Jun 21, 2010 12:30 AM
tym2brn
Oct 30, 2007 02:09 PM
FordCrusherGT
Sep 2, 2007 11:32 AM
compton4x4
Jan 9, 2007 09:57 PM
christer
Freelander
Oct 28, 2006 03:47 PM
