Front wheel bearing / hub
Old Mar 22, 2016 | 02:57 PM
  #31
clint70's Avatar
Found the issue... Bad ABS sensor. However Erik at Lucky8 has been super to deal with, a new sensor should be on the way. Thanks Lucky8 and here is to getting those 3 Amigos off the dash (soon).
Old Mar 22, 2016 | 03:31 PM
  #32
OffroadFrance's Avatar
Originally Posted by Charlie_V
Separating the hub takes a huge torque wrench and 300 pounds of torque to seat the new one. If you have good hubs use them with the shaft connected. That way you just have some bolts to take off and put on. There is an o ring in the hub (I can't remember whether that is front, back, or both) but if your donor isn't leaking I wouldn't mess with it. I would also take the whole thing off without disturbing the ABS sensor if you can. Just swap it all over.
You've got the rave but my recollection is jack it up, remove he tire, remove the caliper, remove the rotor, then take 5 bolts off the back. Beat the hub off (don't use pry tools if you can avoid it) and slide it out. Slide the new one in and be sure the end of the shaft goes in the differential, then button it all up.
If you raise the axle a bit you won't get gear oil everywhere.
Seals in the front axle and O rings in the back axle. For very few bucks it pays to replace them all when pulling the shafts.
nickm347
Jan 10, 2016 11:28 AM
Externet
Aug 26, 2013 06:45 PM
Grlica
May 1, 2013 06:13 PM
Quiksilver1850
Nov 25, 2008 01:05 PM
