Front wheel bearing / hub
Found the issue...
Bad ABS sensor. However Erik at Lucky8 has been super to deal with, a new sensor should be on the way. Thanks Lucky8 and here is to getting those 3 Amigos off the dash (soon).
Separating the hub takes a huge torque wrench and 300 pounds of torque to seat the new one. If you have good hubs use them with the shaft connected. That way you just have some bolts to take off and put on. There is an o ring in the hub (I can't remember whether that is front, back, or both) but if your donor isn't leaking I wouldn't mess with it. I would also take the whole thing off without disturbing the ABS sensor if you can. Just swap it all over.
You've got the rave but my recollection is jack it up, remove he tire, remove the caliper, remove the rotor, then take 5 bolts off the back. Beat the hub off (don't use pry tools if you can avoid it) and slide it out. Slide the new one in and be sure the end of the shaft goes in the differential, then button it all up.
If you raise the axle a bit you won't get gear oil everywhere.
nickm347
Jan 10, 2016 11:28 AM
Externet
Aug 26, 2013 06:45 PM
me 2
Mar 28, 2013 11:02 AM
Quiksilver1850
Nov 25, 2008 01:05 PM
