Front windshield heater to fog lights
Old Jan 4, 2013 | 05:42 PM
toofaroffroad's Avatar
Default Front windshield heater to fog lights
2000 Disco 2 115000 miles.
Hi, I recently had a new front windshield installed and did not go with the heated version. I had a great idea to use the switch and wiring to hook up my hella 500 straight beem lights. It didn't seem to work. When you press the front winsheld heater button the little light still pops on so I don't think it's a fuse issue. Is my idea a bad one? Any idea why it woudn't work?
Old Jan 4, 2013 | 06:05 PM
jafir's Avatar
Did you check for power with a multi meter?
Old Jan 4, 2013 | 07:55 PM
Fallstaff's Avatar
The windshield is also on a timer, so your lights will go out every 5 minutes!
Old Jan 5, 2013 | 12:26 AM
The BCU controls the front screen, the little switch tells the BCU you are requesting operation, and it turns on the relay in the under hood fuse box and powers up fuse 7 & 8.
Old Jan 5, 2013 | 07:19 AM
Plus you would have to run the fog lights thru a relay to get the proper voltage if everything worked, which it won't as described above.
Snowdog
Apr 7, 2016 01:05 PM
Frank4
Nov 21, 2015 05:47 PM
abran
Oct 1, 2013 09:09 PM
jordamf
Aug 2, 2011 09:04 AM
pmccomas
Dec 3, 2008 07:45 PM
