Fuel leak?
Old Jan 14, 2020 | 07:40 PM
Earl_the_disco's Avatar
8th Gear
Default Fuel leak?
Hey everyone! I'm new to the forum and the discovery culture. Just got my truck a few weeks back, it's in pretty decent condition. Runs really well. Just last week, I noticed that the fuel tank had wet spots running down it, and there was this smell of gas. So I knew I had a fuel leak. It was fine since though, even made a 6 hour trip last week through the mountains no problem. Just today though, it died at a red light. The rpms sorta just dropped and then it died. Anyone know what could have caused it? I'm thinking it might be either a leak in one of the lines that caused it, like maybe too low fuel pressure? Or maybe a bad sender unit? Input would be great! Thanks!
Old Jan 15, 2020 | 06:37 AM
JUKE179r's Avatar
Welcome to the forum.
The issue could be low fuel pressure due to fuel leak, bad fuel pump, bad fuel pump relay or bad crankshaft position sensor (CPS/Cpk)... or all the above.
First sort out that fuel leak, and second, check your Disco 2 for fault codes with an OBD diagnostic tester. Post all the codes here.
Old Nov 30, 2020 | 10:35 AM
Kapow's Avatar
3rd Gear
My 95 Disco had the vent hose neck on the tank detach. When I filled the tank all the way, some leaked out from the fitting. I have fixed it twice, but the thing keeps coming detached. I have tried JB weld and am still trying to find a permanent fix without replacing the whole tank. I had no trouble with it running though and still drive it almost every day.
Old Nov 30, 2020 | 11:07 AM
Externet's Avatar
Hi.
Dealt with the leak a few days ago.
----> https://landroverforums.com/forum/di...l-pump-102944/
Ended fine but could had it done by just plugging the 'white cross' with epoxy/jweld instead.
Post #7 at ----> https://landroverforums.com/forum/di...-pumps-102803/
Shows the fuel puddled on the 'white cross'
And found the black pressure sensor is transplantable to a new pump that does not feature it by drilling a hole at the correct location.
Old Nov 30, 2020 | 06:24 PM
nashvegas's Avatar
It died -- but were you able to restart it?
My experience with these trucks is that .. when they suddenly die like you turn the key off at a light, it's generally the CPS (crank position sensor). Doesn't sound like related to your leaking fuel issue.
m1rc
LR2
51
Sep 6, 2022 06:23 PM
richarddeel
LR4
Jul 23, 2017 08:14 PM
Zulu1
Oct 21, 2016 08:28 PM
DSCVRY
Dec 6, 2012 12:42 PM
mick robinson
Jan 2, 2009 08:29 PM
