Fuel Leak When Filling
I have only fueled my Discovery once (been working on it ever since
), but when I tried to top it off, it leaked gas out of what seemed like the middle of the truck. I took the access panel off, and notice that the hose shown in the diagram below wasn't connected. (The one that goes to the fuel pump assembly)
![Name: Fuel_Tank.jpg
Size: 33.8 KB](https://landroverforums.com/forum/attachments/discovery-ii-18/48152d1501388324-fuel-leak-when-filling-fuel_tank.jpg)
Is this the vent hose? I thought I read that it was a 3/4" hose. The hose in question does go up to the filler neck area though.
Just wanted to see if I was chasing my first problem, or if that hose being off could have been another problem I didn't know about.
![Frown](https://landroverforums.com/forum/images/smilies/udbMv2o.png)
All fuel tanks have a vent tube, there is also one on the filler neck.
There is the filler neck and then a smaller tube that runs parallel to the filler neck to let air vent when filling the tank.
There is also a small hose that runs to the engine compartment from the gas tank and then back again to let pressure vent when the car is parked.
it vents into a canister usually known as the carbon canister, it collects all the gas vapors and returns them as liquid back to the gas tank.
it is a closed system and if there is a leak it will set a fault code. (EVAP leak)
In the old days before non vented gas caps all the vapors went into the atmosphere.
