Fuel rail to line connector
Old Mar 31, 2013 | 06:35 PM
pinkytoe69's Avatar
Default Fuel rail to line connector
The button on the connector that attaches to the fuel rail was broken off.
I had to use a couple pliers and leveraged the connector off the line.
I have the actual connector wrapped up, but I have an image of the purge valve one which is broken in the same way.
Any advice on replacing?
Old Apr 1, 2013 | 07:48 AM
drowssap's Avatar
if you just missing the locking (clip kind of C shaped) you can buy them, some fiuld flilter come with them in the box.
Old Apr 1, 2013 | 11:21 AM
pinkytoe69's Avatar
Oh wow.
I had no idea you can just buy the clip/button. Looks like O'Reilly has a bunch of Dorman brand.
Thanks!
Old Apr 1, 2013 | 11:24 AM
drowssap's Avatar
just grab a box and shake it to see if there are in there, if not try the HELP section that most ap store have there usually sell stuff like that
Old Apr 1, 2013 | 12:17 PM
pinkytoe69's Avatar
Are the d2 lines 5/16"?
Old Apr 1, 2013 | 12:55 PM
drowssap's Avatar
dont know
Old Apr 5, 2015 | 05:07 PM
me6067's Avatar
I am in the same situation as pinkytoe69. My connector is broken, any suggestions on replacing it? does anyone know what the fuel line size is that the connector is attached to? I managed to get the clamp that secures the connector to the line but I am not able to remove the connector from the line.
Old Apr 5, 2015 | 05:30 PM
me6067's Avatar
Turns out I am only missing the c-clip. Has anyone had to replace their c-clip? and are they easy to find that fit right into our connectors?
Old Jun 17, 2015 | 09:23 PM
me6067's Avatar
I ended up switching the same c clip from my evaporate line that goes to the manifold onto the more important fuel line. Fuel line is now secure and have found alternative connector that doesn't need to be as reliable to use on the evaporate line.
rcrosby
Apr 13, 2011 02:56 PM
JumPeR04
Apr 7, 2011 09:52 PM
JumPeR04
Apr 1, 2011 04:15 PM
jbond0076
Mar 16, 2007 10:11 PM
fromdabigapple
Apr 3, 2006 06:20 PM
