full battery,, turns on doesn't crank.
Old Sep 26, 2014 | 08:21 PM
sDot's Avatar
Default full battery,, turns on doesn't crank.
I had the pleasure of being stranded after work today, definitely not fun.
My battery has full power, and when i turn my key it does not crank. It is not turning over. The dash lights that come on are the check engine, oil and battery. I took the batter to get tested at a parts place and it's good.
I haven't had this problem before so I have to ask they pros what you think?
Old Sep 26, 2014 | 08:33 PM
billlapinga's Avatar
Crankshaft position sensor. On drivers side where engine mates to transmission behind the exhaust manifold.
Old Sep 26, 2014 | 09:04 PM
GROVERDISCO's Avatar
Make sure the shifter is all the way in park
Old Sep 26, 2014 | 09:30 PM
sDot's Avatar
that it was.
Old Sep 26, 2014 | 10:25 PM
cappedup's Avatar
Hit the starter with something. Do you get a click, anything?
Old Sep 27, 2014 | 04:11 AM
Richard Moss's Avatar
Immobilser Activated?
Old Sep 27, 2014 | 06:56 AM
james.martin1's Avatar
How old is the battery? Do the lights dim when you turn the key?
Another thought: One time I remember I unlocked my door and went to get in and it did the same thing yours is doing. I took the key out and hit unlock again and put the key back in and it started. Not sure if it was the immobilizer or what caused it, I never really looked into it after that.
Old Sep 27, 2014 | 07:14 AM
sDot's Avatar
The battery is strong, I don't know why the immobilizer would kick in. I basically drove to work and when I went to leave it wouldn't start. no dimming of the lights and everything works good.
when i turn it, it makes a click. but I think that click but I don;t think that is from the engine.
It's not cranking or turning over. I have no previous ignition problems.
If it was the starter wouldn't I have warning signs before hand? If it was the crank sensor, wouldn't it still crank, but not start?
Lord Wert
Jul 4, 2013 07:52 AM
mbeasom
Sep 23, 2011 02:25 PM
charlielr2
Feb 24, 2010 06:51 AM
golfman
Dec 22, 2006 09:22 PM
arrkerr
Dec 14, 2005 10:06 AM
