Which is the fuse to clear 'Check engine' light ?
Old Jul 10, 2018 | 01:32 PM
Externet's Avatar
Question Which is the fuse to clear 'Check engine' light ?
I forgot which fuse has to be pulled for a few minutes to clear the engine control unit error codes. Refresh, please ? My code reader is not doing it and prefer not to disconnect the battery.
Old Jul 10, 2018 | 02:17 PM
JUKE179r's Avatar
Try this from SavanahBuzz for a Disco 2...
https://landroverforums.com/forum/ra...59/#post356021
Old Jul 10, 2018 | 02:29 PM
The Deputy's Avatar
That topic is about the service reminder, l believe. There isn't a fuse that will clear codes, especially existing, without a scan tool. Some cars would have a service reminder, but it is getting pretty rare. Usually, you see these service reminders, if there is an internal part that needs to be replaced (timing belt, etc).
Brian.
Old Jul 10, 2018 | 02:31 PM
The Deputy's Avatar
If your code reader isn't clearing codes...most likely...they are active codes.
Brian.
Old Jul 10, 2018 | 02:50 PM
The Deputy's Avatar
Was mistaken...Land Rover does have a "service reminder" on th Dll...it's when the head gaskets blow...then you know it's time for a new engine.
Then there british are brilliant.
Brian.
Old Jul 10, 2018 | 03:57 PM
mln01's Avatar
Just disconnect the battery.
Old Jul 10, 2018 | 09:05 PM
LandBeard's Avatar
Just snip the lead to the light...
Old Jul 10, 2018 | 10:56 PM
Dave03S's Avatar
Scotch Super 88 under the Binnacle by Coronal Mustard in the library.
colemtd
Nov 18, 2016 04:48 PM
bostongrun
Sep 14, 2015 08:06 AM
jfall
Jan 30, 2013 10:55 AM
disco2newb
Jan 9, 2012 06:58 AM
jimpty
Nov 19, 2011 11:16 PM
