Gas cap door cover problem
Old Jun 27, 2013 | 11:14 PM
tcfreas's Avatar
Default Gas cap door cover problem
The pin that holds the door closed will not retract while the door is open. Has anyone run into this and know how to fix it?
Thomas
2003 Disco II 126K miles
Old Jun 28, 2013 | 12:33 AM
WD 40 or PB Blaster? And while you are at it lube the hood latch cable at both ends also.
Old Jun 28, 2013 | 08:07 AM
ZGPhoto's Avatar
Are you referring to the little metal piston that retracts to open the door?
Old Jun 28, 2013 | 09:36 AM
Zonk872's Avatar
Buzz where is the other end? I lubricate most all of my hinges including gas door piston. I also use lithium grease on the front hood mechanism.
Old Jun 28, 2013 | 10:41 AM
groeder24's Avatar
I believe that pin only retracts when the fuel door button is pushed and comes back out when the button is released. More of a solenoid than anything.
Old Jun 28, 2013 | 10:46 AM
ZGPhoto's Avatar
^That's why I was asking if he's referring to the piston. It doesn't stay in, it only goes in to release the door, then shoots back out to catch the door as it comes back in.
Old Jun 28, 2013 | 01:32 PM
jwigum's Avatar
That rod should stay extended as long as the button isn't pressed(at least it does on my 2003).
There's a small plastic catch on the door that pushes up and over it to hold the door closed. When you push the fuel door button on the console, the rod retracts, which allows the door to open.
coloradomtns
Sep 23, 2013 09:40 AM
cocca
Jan 26, 2009 08:40 PM
Camdisco24
Apr 29, 2008 11:14 AM
dammad
Apr 21, 2008 10:48 PM
Bob2003Discovery
Mar 27, 2007 11:57 PM
