Gears
Old Dec 21, 2009 | 11:59 AM
gsgtsg's Avatar
Default Gears
Hi,
Please excuse my ignorance.
I have an automatic Discovery 2 and would like some information on the following:
1) High/Low Gears:
a) How do the High/Low gears work?
b) When should the respective gears be used?
c) Are there any conditions/limitations that should be followed when using them?
2) Can I shift the gear stick between D, 1, 2, and 3 WITHOUT stopping the vehicle?
Cheers.
Old Dec 21, 2009 | 02:55 PM
hilltoppersx's Avatar
high gear should get you thru nearly everything. you can go from 1, 2, 3 and D without stopping yes. to shift into the low or high you must be stopped and in neutral. to use the HDC you must be in low. i wouldnt go faster than 25 in low but others will say you can go faster than that.... welcome to the madness.
Old Dec 21, 2009 | 09:41 PM
The rev limiter will keep you from going to fast when in low.
Low range should be used when off roading, deep snow, pulling the boat out of the water, pulling stumps out of the ground etc.
Basically anytime you need maximum torque.
Hi range is for normal driving, it is a full time four wheel drive so you are always in 4x4.
When driving off road I always put the transmission in 2nd gear and keep it there unless going down a big hill then I put it in 1st.
Old Jan 5, 2010 | 04:52 PM
gsgtsg's Avatar
Hi,
I have an automatic Discovery 2. What gears would you recommend that I should use in snow / icy weather?
Cheers.
Old Jan 5, 2010 | 05:32 PM
lipadj46's Avatar
Keep it in high as long as your traction control is working (no 3 amigos) you will have no problems. If you get in really deep stuff and need to go slow then put it in low.
RoverLand
Oct 18, 2006 09:55 PM
BMWLR
Sep 7, 2006 03:21 PM
extremetoy1
Jul 14, 2006 12:28 PM
Acer
Mar 29, 2005 07:27 PM
Acer
Feb 25, 2005 10:29 PM
