Gears shifting weird
Hi everybody,
I have a Discovery II 2002 , and recently I have noticed that if I pass more than 2000 revolutions the gearbox starts acting weird and shifts downwards to another gear, and then goes back to the original gear. What do you think could be the problem? I have automatic transmission and this happen going more than 40mph.
Thanks
Nelson
Thanks
Nelson
RE: Gears shifting weird
Yes it could.
The tansmission on a DII is electronic and if the transmission computer is not getting the correct voltage it will act up.
If the voltage gets to low the "M" and "S" lights will flash on the dash and the trans will go into "limp mode", you will only have 3rd gear.
ORIGINAL: sosico
Thanks for the information
I will have the alternator replaced and see if that fixes the issue.
tre soli
01-01-2014 12:40 AM
