general maint/upgrades
Old Dec 22, 2007 | 07:58 PM
rcendo's Avatar
7th Gear
Default general maint/upgrades
Just bought a 98 Disco with 80K on it. Any ideas/suggestions on general maintenance or upgrades (plugs, oil, filters, serp belt, etc) would be much appreciated.
I think I am really gonna like this beast!
Old Dec 22, 2007 | 08:19 PM
Default RE: general maint/upgrades
Here is my "MUST" list.
This is the parts list for a 60,000 mile service or a high mileage used truck, the way I do it.
1 Oil filter, K&N 3001
1 Air filter
6 Qts of engine oil
12 Qts of ATF
7 Qts of 80/90W gear oil
2 Qts of Brake fluid
2 Qts of synthetic Power steering fluid
2 Gallons of OAT, orange coolant
1 Bottle of Lucas Power Steering additive
1 Bottle of Lucas Transmission additive
1 Can of Spray Carb. Spray
1 Can Of Brake cleaner
8 Spark Plugs, I use Bosch Platium Plus 4's
1 Set of Magnacor 8mm plug wires
1 Serpentine belt if not yet replaced
2 Bottles of SeaFoam
60,000 Mile Service or Major Service for High Mileage Used Vehicle just purchased
Bleed the brakes
Flush and change the power steering fluid adding one bottle of additive
Service the tranny adding one bottle of additive
Flush the coolant system
Do an engine flush before changing the oil
Do an induction cleaning
Clean the throttle body
Add fuel additive to full gas tank
Change both of the diffs fluid
Change the t/case oil
Replace the plugs and wires
Replace the air filter
Lube all the drive shaft grease fitting including the 2 slip shafts
Do full inspection of brakes, hoses, bushings etc.
Hopefully I didn't leave anything out.
Mike
theworks001
Sep 19, 2008 12:46 PM
blueovaltech
Jun 10, 2008 01:41 PM
blueovaltech
Jun 3, 2008 09:07 PM
pxm045000
Nov 3, 2007 12:55 PM
