getting heat through the drivers side floor
Just curious if this is a issue with discos. I noticed that heat is coming up from the floor or somewhere on the drivers side after driving for a bit. I have checked to make sure the ac is set to cold incase the air is still coming out of the vents but thats not it. No heat coming from the pass side floor.
just for reference: you know there is no heater control valve on a disco so you will either have heat or cooling coming out of your vent even when off.
The reason I ask is this comes up every spring, even when off it will still try and put out the last temperature it was set at.
personally I hit the ecno button and set my temps close to OAT, that shut off the compressor and only uses outside air.
