Got the dreaded oil light today...
Old Mar 27, 2009 | 11:26 AM
  #21
jycsalas's Avatar
Originally Posted by okdiscoguy
...I plan to go right above the tweeter on the a pillar. I have been wanting to do a temp gauge because the actual temp fluctuates a lot more than the factory gauge reads.....
Using the scangaugeII to monitor the water temp, you are absolutely right.
Every morning when I turn my DII on, it takes about 2-3 min to get the temp needle at "normal" (half way on the gauge) while this happens, the scangauge tells me the following:
At start up, water temp is about 80F and then takes 2-3 min to reach "normal". As soon as the needle reaches the half way mark, scangauge reads 155 degrees F. However, the scangauge water temp keeps rising and usually stays around 187 degrees +/- 3. This is the normal operating temp. I have had it as high as 203 while off roading while needle remained at normal during all of these conditions... the actual temp is fluctuating about 20+/- degrees. I plugged my scangauge into a friend's 04 and her temp was reading 205 while idling... but she was low on coolant...
dillon@zenmoto
Jul 24, 2012 05:14 PM
kman35ca
Nov 26, 2011 11:05 AM
DGoehler
May 30, 2011 08:01 AM
jck09
Jan 24, 2011 09:41 AM
seaosrover
Nov 14, 2010 03:07 PM
