Got My D2, have questions
Old Dec 24, 2011 | 04:35 PM
Andy2Rover's Avatar
Default Got My D2, have questions
Merry Christmas Everybody!
I am stoked, got my 2000 Disco! It has 95k miles, 2 owners, head gaskets have been done, overall seems to be in decent shape but a little neglected.
I plan on doing all the updates suggested here, but was messing around with it today and have some questions....
The rear tailgate door bottom check strap has nothing keeping it on (see pics), and the door if very stiff to open and close. Is some sort of washer supposed to be holding the strap down??
Also noticed a small hose(? vacuum line ?) along the drivers side firewall that is cut and goes nowhere. Could this be why my cruise control isnt working?
And one final thing.....There are Hella driving lights mounted on the front brush bar. They arent working! There is a button on the dash that I assume controls them, when I press it, the indicator light doesnt come on, and the switch does not lock in the on postion, just springs back.
Thanks in advance guys! This is a very helpful forum!
Andy
Attached Thumbnails Got My D2, have questions-land-rover-1102.jpg   Got My D2, have questions-land-rover-111.jpg   Got My D2, have questions-land-rover-112.jpg   Got My D2, have questions-land-rover-114.jpg   Got My D2, have questions-land-rover-115.jpg
Old Dec 24, 2011 | 04:56 PM
1. Download the set of factory shop and owners manuals, called the RAVE, for free, below.
2. The Hellas would require an interface relay. Normal front fogs will work with high beams on. Wiring diagram of the factory stuff is in the RAVE (circuits diagrams).
3. The hard line may also be a vent line to differential or transmission/transfer case.
Old Dec 24, 2011 | 05:36 PM
lordmorpheus's Avatar
Tail door check strap: I will have to get back to you tomorrow because mine is in the garage witht he door closed already and the wife would frown on me opening the garage door just to open my tail door and look.
Plastic hose on driver's side firewall: vent tube for front axle. The transfer case and transmission vent tubes come forward from the transmission tunnel and terminate on the passenger side of the rear of the engine.
Hella driving lights: Only operate when high beams are on, if wired OEM. If OEM, there should be a small relay box bolted to the rear (firewall side) of the underhood fuse box. There is a fuse in that relay box, also that relay box is known to have internal issues, requiring a rewire.
PS: Merry Christmas to you, also! and X2 on downloading the RAVE!
Old Dec 24, 2011 | 07:04 PM
Andy2Rover's Avatar
Thanks Lordmorpheus and S. Buzz for the replies!
I will check for the relay box and fuse....hopefully just a blown fuse!
Downloaded the Rave already, trying to get it on my iphone too but having some technical difficulties....I am from the analog age LOL
Old Dec 24, 2011 | 08:07 PM
Jordanpryce's Avatar
Rear door hard to open or close, look under the door for a separated or rusty seam. Also lube up the door stop rail with white grease. you will see the rail through the cutout under the door.
Old Dec 25, 2011 | 10:10 AM
Pix of rear door stop snap ring. Un-lubed.
Old Dec 25, 2011 | 02:59 PM
Andy2Rover's Avatar
Thanks S. Buzz that's exactly what I needed!
The obvious next question is how would I get ahold of the washer and circlip? Is there a part# to get it new?
Thanks!
LR 4 LIFE
LR4
Sep 15, 2014 09:25 AM
glassman66
Jul 7, 2012 03:10 PM
Analogkid
Oct 28, 2010 05:38 PM
lipadj46
Sep 12, 2009 07:31 AM
Disco2Fever
Oct 19, 2008 08:05 PM
