Got the new tires. Went up a size, so far, so good.
Old Aug 15, 2011 | 01:13 PM
  #21
photocrimes's Avatar
Originally Posted by marshman442
I'm thinking about doing the same thing. about how long did it take you to do? Any tips or things to look out for? Did you trash any of the clips pulling the interior door panel off?
About an hour. It's not that hard. I have a metal working shop and probably took more time than needed making the notch for the wiper look factory. I painted the notched area too. Pretty straight forward. I drilled new holes and still used all six bolts.
Tips, be careful with the metal spacers. Good to have another set of hands to hold them just in case. They'll scratch and ding your door if/when they fall off. I just took all the nuts off and left it balancing ever so gently until I walked around and took the carrier off.
I only busted 2 of the clips. If I had been thinking I would of made a little tool to pop them. They are 11 years old and brittle though. You do get a second chance even if you break one however! Just grind/sand the clip down to the next unbroken round part and slide that in the panel slot. You'll see what I mean. Works perfect ;-)
Next time I will need to buy new ones though.
Ezilandguy13
Mar 8, 2015 04:04 PM
Kyra96Disco112
Oct 31, 2011 12:02 PM
SDinDS
Jun 27, 2011 08:58 AM
Chrisinhouston
Jan 19, 2009 06:57 PM
hollis
Feb 15, 2008 08:29 PM
