Grease centering ball
Old Jan 7, 2017 | 03:55 PM
Charlie_V's Avatar
Default Grease centering ball
Will someone tell me what to buy to grease my centering *****? I have newish GBR HD drive shafts and there is a tiny fitting that just looks like a hole with a ball bearing in the end . I got a "needle fitting" from the local parts store for my grease gun that is about 2 inches long and just looks like a long syringe . I've poked it into the hole but I don't feel like I am doing any good . I have double cardans front and back and feel like I'm not being a good Rover owner .
Old Jan 7, 2017 | 04:14 PM
LR03NJ's Avatar
I went to advance auto and got the grease gun and a grease tube. I just found out that you have to loosen the end of the grease hose, fit that on the nipple and tighten it before you squeeze the trigger. I have the same heavy duty GBR shafts from a while back.
I did not use the long syringe just insert the metal end of the hose and lock it.
Old Jan 7, 2017 | 05:15 PM
OverRover's Avatar
To grease a low profile zerk you do use a needle fitting, but one with a larger angle tip. It's wide enough to cover the ball bearing in the fitting. You can get them at Napa, AZ, Advance Auto( #LIN5803) McMaster Carr, etc or online. They also come in different lengths.
Old Jan 7, 2017 | 05:31 PM
Charlie_V's Avatar
Wow! . Overwhelmed with the quick responses. Thank you! I'll let you know how it goes.
Old Jan 7, 2017 | 06:34 PM
OverRover's Avatar
A seal-off needle fitting will also work for grease plugs/low profile zerks. These come in different lengths and diameters too.
Like this > Performance Tool W54214 - Dispenser | O'Reilly Auto Parts_
Old Jan 8, 2017 | 01:50 AM
number9's Avatar
I've poked it into the hole but I don't feel like I am doing any good.
When you pump the gun, if grease immediately comes out at tip/ball valve it's likely not going in the fitting. Sometimes the ball/check valve gets stuck closed and poking with a scribe or pick will free it to open. You probably remember having the same issue with a stuck grease nip/ball is sticking when it all comes out of the gun fitting. Other times grease tip is too large or too small to seal well.
geotrash
Apr 20, 2009 02:15 PM
MarvelVT
Mar 24, 2009 07:07 AM
jw928
Feb 28, 2009 10:26 PM
holly5
Jan 24, 2009 12:28 PM
Night Train
Nov 28, 2008 11:17 AM
