What is a centering ball?
Old Mar 23, 2009 | 11:00 AM
MarvelVT's Avatar
Default What is a centering ball?
While I have my transmission out I figured I would replace my u-joints but looking on the forum I see that I also need to replace a "centering ball". I looked on rave and couldn't find out what that is. What is this and where is this located? If I'm replacing u-joints I'd like to do a full replacement of the assembly. I bought four Precision 344 u-joints. What is the part number for this centering ball and how many do I need?
Thanks
Old Mar 23, 2009 | 11:03 AM
Street Wolf's Avatar
Give me a moment, I'll walk out to the shop and see if I can find the part number. You can get it at a local O'Reilly or someplace.
And you only need one.
Old Mar 23, 2009 | 11:09 AM
Precision #617 is what you need
Old Mar 23, 2009 | 11:15 AM
MarvelVT's Avatar
Thanks a lot. Quickest response time ever. I have no idea what it looks like so could you tell me where this goes?
Old Mar 23, 2009 | 11:24 AM
It's going to be located inside of the knuckle part of your driveshaft on the side that is connecting to your transfer case. Like below-
It's basically just a round metal ball. Once you get that part of the driveshaft apart you can easily get to it.
You can kind of see it in this pic-
Old Mar 24, 2009 | 01:36 AM
MarvelVT's Avatar
Street Wolf thanks so much for taking the time to find that part number and also the awesome pics of it. I do have one more question. I'm starting to feel really dumb but does this centering ball only exist on Disco II and later? I have a '97 Disco I and I do not have that added joint where the ball rests in your photo.
Old Mar 24, 2009 | 04:54 AM
Lol, I believe so. Certainly saves you some work at least.
Old Mar 24, 2009 | 07:07 AM
AK Rover's Avatar
Only the D2s use the double cardon joint in the front driveshaft. Your 97 will have 3 u-joints, 2 in the front driveshaft and 1 in the rear. At the rear pinion it has a roto-flex coupler that you should probably replace since you're doing the u-joints anyway.
clemson rover
Jun 21, 2009 08:15 PM
geotrash
Apr 20, 2009 02:15 PM
jw928
Feb 28, 2009 10:26 PM
holly5
Jan 24, 2009 12:28 PM
Night Train
Nov 28, 2008 11:17 AM
