Greasing drive shaft
Old Jun 15, 2021 | 05:07 PM
redwhitekat's Avatar
Default Greasing drive shaft
Just got a new driveshaft from a place out of Florida. Guy told me to grease everyone couple years. I know here we say it’s every oil change.
what’s your thoughts on this ?
im in the hvac field and we usually grease motors and bearings twice a year but they usually run 16 hours a day
Old Jun 15, 2021 | 05:12 PM
greisinb's Avatar
I do mine every other oil change. It's probably overkill but as long as I'm down there waiting for the last of the oil to drain out anyway might as well get it done.
Old Jun 15, 2021 | 07:48 PM
The Deputy's Avatar
On our 03, wife's/no off road, grease joints every 5000 (when l change oil on the 5's) and lube cardan joint with penetrating spray that turns to a gel. Then on the 10's oil change, l drop the shaft and lube the cardan joint with grease gun.
On my old 01, every 3000 or immediately after 4 wheeling in mud/water. Between the lift, oversized mud tires and extra weight (overlanding)...it needed extra attention.
Our Dll's see a lot of snow and road salt...also...and this maintenance program has worked fine. 03's shaft is five years old now (probably 35K) and my 01's is on our 04 now (45K).
Old Jun 15, 2021 | 08:40 PM
04disco2va's Avatar
What kind of grease do you recommend. Believe I read on my driveshafts it requires NLGI 1. There are so many different types.
Old Jun 16, 2021 | 01:14 PM
NVDiscovery's Avatar
I find it easiest to grease my driveshafts at every oil change. Better safe than sorry I suppose.
Old Jun 16, 2021 | 03:25 PM
Extinct's Avatar
Another vote for every oil change. I use mobil 1 synthetic so the cat converter heat does not cook it out so easily.
Old Jun 18, 2021 | 10:27 AM
04disco2va's Avatar
So which one of these Extinct?
"><img src=" /> ">
"><img src=" /> ">
Old Jun 19, 2021 | 06:35 AM
Extinct's Avatar
Middle one, top one is semi-synthetic, bottom one is not synthetic. Middle one has higher temp resistance
Old Jun 19, 2021 | 07:50 AM
04disco2va's Avatar
Got you. Thanks Extinct !
cimomd
Sep 23, 2017 04:54 PM
mx468
May 12, 2012 10:31 PM
Ad!
Mar 7, 2012 05:14 AM
Rearden Steel
Aug 29, 2010 08:04 PM
KBW
Aug 23, 2009 12:15 PM
