Gutting the air conditioning system
Old Sep 13, 2017 | 04:24 PM
Jeff Blake's Avatar
Default Gutting the air conditioning system
AC has never worked, I don't use it, so I thought it would be nice to gut out the components to save some engine bay space, weight, and one less bearing to worry about on the belt.
Has anyone done this?
Is there a shorter belt that would work? No ACE.
Old Sep 13, 2017 | 04:34 PM
OverRover's Avatar
Alex_M did this > https://landroverforums.com/forum/di...35/#post538216
So at least the legwork for the belt size is done, now just pull the compressor.
Old Sep 13, 2017 | 05:02 PM
Alex_M's Avatar
Yep, still running mine like that. It actually takes two bearings out of the equation because you also remove the idler pulley.
Old Sep 13, 2017 | 05:46 PM
Jeff Blake's Avatar
Bonus!! Sweet. I'm going to get on this. Did you also gut the condenser, pipes, etc?
Can I drain the refridgerant myself or do I need to take to auto shop? And if I take to the shop, can I drive with the compressor still installed and empty?
Old Sep 13, 2017 | 06:33 PM
The Deputy's Avatar
Even though mine works...was thinking about removing system. Might add a couple more horses, and getting the condenser out of the way would promote better air flow. Thought about wiring up the fan to an independent switch, so I can control it while crawling through the woods at minimal speeds.
Belt info is great, Thank you, Over Rover!
Brian.
Old Sep 13, 2017 | 06:55 PM
Jeff Blake's Avatar
Brian.
switch is a good idea. I wonder if the fan would still kick on if the engine reaches 210F with the a/c deleted?
If I'm on a trail, I'll use 4-lo even if I don't need it. Keeps temps down an extra 10+ degrees
Old Sep 13, 2017 | 06:59 PM
Jeff Blake's Avatar
This is the belt I ordered: More Information for DAYCO 5070700DR
Should work the same as the Duralast (couldn't find it) as its still 70" and 7-groove
Old Sep 13, 2017 | 08:02 PM
Red5's Avatar
Or keep the compressor and use it for onboard air.
Old Sep 13, 2017 | 08:54 PM
Alex_M's Avatar
I left the pipes but removed the condenser. Not sure on the refrigerant; I would take it to a shop. Should be easy for them. I didn't have any in my system because I stuck a screw through my condenser. Whoops.
Brian.
I can tell you there is zero power difference because the compressor is not spinning all the time; it's on a magnetic clutch pulley so when the AC is off it just acts like another idler pulley.
Yes, it does, though I plan to wire mine up on an independent switch anyway.
It's not an air compressor, it's an AC compressor. To my knowledge you can't air anything up with it.
Old Sep 13, 2017 | 09:22 PM
OverRover's Avatar
It will work, that Dayco Belt is 100% cross ref for the Duralast Belt. Just my 2 cents, next time get the Gates K070701 (Napa 25070701) > More Information for GATES K070701
Re: the refrigerant, it just depends on how "green" you are. Sure if you want to send it into the atmosphere you can, but it's on you. "Green" or not I'd take it to a shop. And yes you can drive the truck no worries with an empty AC compressor.
Brian, " Belt info is great, Thank you, Over Rover! ".
>> The credit has to go to Alex_M for the AC belt hack, I just remembered that he did it. And don't ask me how because I can't remember where I put my car keys last.
