Hand Brake Cable
Old Jul 11, 2016 | 06:23 PM
CollieRover's Avatar
Default Hand Brake Cable
I am totally stumped by the hand brake cable. When I released it from the lever the mechanism attached to the button is now wedged in front of the hole and I cannot move it.
I have searched, but I can't seem to figure out how to move it so I can replace the cable?
Anyone have a way to do it?
Old Jul 11, 2016 | 09:03 PM
When I released the handbrake cable the spring inverted. I removed the center console, and when the handbrake lever was straight up I was able to manipulate it.
I have it back in, but now the spring is not setting right so I am going to have to come up with some way to reset the spring it is not sitting correctly. So when you pull up the hand brake it is not clicking and reseting.
Old Jul 13, 2016 | 11:51 AM
I found this and it seems to do a good job explaining the issue.
Handbrake, button sticking in
Old Jul 17, 2016 | 04:30 PM
When I released the hand brake and the spring flipped over, somehow the mechanism was bent up hear the button. So, take off the button and use a needle nose pliers to bend it so it sits in the middle of the hole. That solved the issue totally for mine.
ucanthandleme
Nov 20, 2013 05:39 AM
Miwo
Mar 16, 2011 02:01 PM
Arthur
Nov 4, 2006 06:52 PM
psg
Oct 2, 2005 02:07 PM
