Sponsored by: CARiD
Hot hand brake cable
Old Nov 17, 2013 | 12:31 PM
ucanthandleme's Avatar
Default Hot hand brake cable
I have a 2002 disc 2 land rover. The hand brake cable in counsel turns glowing red (burnt wiring near it) when turning over (14 amps) but cools to normal when running. Checked all ground wires and connectors under hood and under body. Added a second ground wire from battery to body. Will turn over fine at first but then battery dies (battery is newer and had it tested) but will then start with a jump. Starter and selinoid new. What is going on?
Old Nov 17, 2013 | 02:10 PM
Transmission to frame and engine block to frame jumpers need attention. You can "test" with a battery jumper cable from block to negative battery, etc.
Old Nov 18, 2013 | 09:51 AM
drowssap's Avatar
yep your missing a ground somewhere, you might want to check the ground on the back of the head to the firewall
Old Nov 20, 2013 | 05:39 AM
OffroadFrance's Avatar
Agree with both above. Definitely defective earth grounds somewhere. Also this can cause a lot of damage and a possible cable fire. Needs fixing immediately before using again.
Miwo
Mar 16, 2011 02:01 PM
sn1987
Defender
Nov 10, 2009 11:38 AM
raid13
Jan 16, 2009 03:49 PM
Arthur
Nov 4, 2006 06:52 PM
psg
Oct 2, 2005 02:07 PM
