Hand / Parking brake stuck down, light on
Old Jun 14, 2022 | 01:40 PM
girlfriendboughtarover's Avatar
Default Hand / Parking brake stuck down, light on
Hey all - first off, thanks to everyone in this community. I have been lurking a while and found many helpful answers.
Our '99 Disco 2 (V8) has a hand brake that is stuck down. It really won't budge at all. The 'BRAKE' light is on indicating that the thing is engaged. I know that you can adjust the the brake shoe underneath the vehicle but before I do that, I wanted to see if anyone has had a similar problem. The RAVE says the parking brake should be disengaged before adjusting the shoe and according to the light, it is engaged right now.
Any suggestions would be appreciated. Thanks.
Old Jun 14, 2022 | 04:13 PM
whowa004's Avatar
Check brake fluid as if you are low that light will be illuminated. On the stuck portion it's a simple mechanism so you're on the right track to look at RAVE and trace it down to the brake shoe.
Old Jun 16, 2022 | 09:50 AM
JUKE179r's Avatar
Yeah I was thinking low brake fluid too for the illuminated brake light
Old Jun 16, 2022 | 04:19 PM
DodyDisco's Avatar
I had my parking brake handle get stuck down and found it was lots coins that had somehow gotten into where it pivots and jammed it up solid.
Old Jun 16, 2022 | 04:50 PM
sqlbullet's Avatar
I found just short of $10 of pennies, nickels, dimes and quarters in the center console under belly in my disco during the post purchase clean-up. I was shocked.
Old Jun 16, 2022 | 06:01 PM
Ha! Thank you both. I will investigate.
twcord
Sep 30, 2021 08:17 AM
jmartosella
Range Rover Evoque
Dec 26, 2020 07:10 PM
crznmyway
May 24, 2012 06:34 PM
BIG
Feb 8, 2010 11:46 AM
awillis
Jan 9, 2008 07:34 PM
