Has anybody seen this ABS fault code?
Old May 12, 2013 | 07:49 PM
jthomas's Avatar
Originally Posted by NiteTrain
Thanks bosshogt but I think I'm just going to purchase one. I see this being an on-going issue.
If you're going to buy an ABS amigo, consider an Autel 609 or 619. It is less expensive ($160-$175) than the ABS amigo, and can read ABS and OBD-II engine trouble codes as well. You can use it on over 36 different vehicle brands as well. Click HERE to read a recent thread about it.
You also don't have to connect it to the vehicle, save the codes to the scanner, and then go connect it to a computer to see the codes, like the ABS amigo. You will see the ABS codes right away on the scanner - no extra trips to the computer. The only time you have to go to the computer is the initial FREE software update to be able to read codes on over 36 different car brands.
Old May 12, 2013 | 08:17 PM
NiteTrain's Avatar
Yeah, The Autel looks like what I need since I also am in the market for a OBDII reader.
Old Jun 10, 2013 | 02:19 PM
NiteTrain's Avatar
"shuttle valve switch electrical failure"
Not the code I wanted to see after already replacing shuttle valve.
pwaltrip
Jul 26, 2016 10:00 PM
onewingman
Dec 15, 2013 12:38 PM
06Range
May 8, 2013 09:01 PM
WINDman
Sep 5, 2010 08:43 AM
