Has anyone used a Long wire type ABS Sensor ?
Old Apr 26, 2012 | 10:26 PM
sayeedA's Avatar
Talking Has anyone used a Long wire type ABS Sensor ?
Just curious. I am about to replace RF ABS sensor and came with the long cable type. I read somewhere you are supposed to replace the entire cable all the to ECU. Any help> Looks complicated to mess around with the ECU.
Thanks
Old Apr 26, 2012 | 10:56 PM
LRScott's Avatar
I would save the cable just in case. Its probably not the proper way, but... I would be lazy and just swap the sensor out without changing the cable (especially considering the miles on your rig). If the problem persists, I would change the cable.
Old Apr 26, 2012 | 11:03 PM
sayeedA's Avatar
I tried the stock sensor that just plugs in to a socket behind the battery but failed. the long cable and sensor is one unit I will have to cut and make it fit.
Once I cut it can't put back together.
Thanks for your advice
Old Apr 27, 2012 | 07:48 AM
Have you tested and confirmed it is the speed sensor and not a failing hub? I would do that then go for a sensor if needed. As the which to use, doesn't make a lot of difference as long as you keep the connection clean and use some dye electric, you will not have any issue with the original short wire version.
Bob Jones
Mar 29, 2013 12:25 PM
sayeedA
Apr 23, 2012 09:00 PM
drdabbles
Aug 17, 2010 07:37 PM
Disco Alan
May 28, 2009 05:21 PM
Gavster
Mar 7, 2009 03:44 PM
