Has started to jerk when shifting.
Here within the past couple of weeks the tranny has started to occasionally hesitate and jerk hard when shifting gears. It is not often, but getting more frequent.
Could this be some sort of computer or sensor issue, or is it more likely a sign of an impending tranny overhaul?
Just wanted to get your thoughts on it.
Thank you!
Thank you!
Mine used to do this thing where it would try to engage the torque converter lockup clutch while accelerating, but it would change its mind at the last minute, which created a jerking / abrupt "shift" that was quite alarming.
A fluid drain / refill and new filter made 90% of the problem go away. It still does it very seldom, but I attribute that to the 8+ quarts of old fluid that's still in there. (My drain + refill only replaced 4 quarts).
Thanks Dane,
Now that I think of it, the tranny was flushed by the dealer on my Dodge many years ago during a service and it refused to shift afterward until they drained and refilled it again. If I recall, they explained that the flushing caused a bearing or valve or something to get jammed.
