Have you guys ever seen this before?
Old Oct 25, 2019 | 01:10 PM
Brandon318's Avatar
Default Have you guys ever seen this before?
The throttle body heater plate is actually deformed and bowed due to what I'm assuming is the swelling of the gasket. I held a straight edge up to it and it's about 2-3mm bowed on both sides. That's a ton of pressure.
Old Oct 25, 2019 | 01:42 PM
That is odd. I would almost wonder if it got really hot once
Old Oct 25, 2019 | 01:52 PM
Richard Gallant's Avatar
I bet the someone put a ton of something in there and bent it when tightening the bolt. You notice it is the section with one bolt.
Old Oct 25, 2019 | 02:35 PM
Brandon318's Avatar
It's clearly been replaced once before. The replacement kit I got is the actually LR kit, and the bolts I removed are different head sizes than the ones from the LR kit.
Old Oct 25, 2019 | 02:37 PM
Brandon318's Avatar
The prior owner says it never overheated... and there isn't any indication of head gasket issues or liner struggles. It has 78,000 miles on it, still pretty youthful, ha.
Old Oct 26, 2019 | 12:18 PM
ZGPhoto's Avatar
That is very common(although usually not that intense). This is why you get the new plate with the gasket, because they are prone to warping
nmacej
Sep 19, 2019 07:26 PM
Alex_M
Nov 19, 2017 03:38 PM
Matthew White
May 11, 2017 05:51 PM
cbrf23
Dec 30, 2014 06:40 PM
Creed0330
Feb 15, 2012 03:30 PM
