having trouble starting when cold
Old Feb 18, 2013 | 08:12 AM
mtrdrms's Avatar
Default having trouble starting when cold
Hi all. I just did the headgaskets on my 00 and it runs good again! Only issue I'm having now is when I start it in the morning it won't idle for the first minute or two. I have to help it along with a little throttle. Then its great. It seems like its loading up with fuel but notsure. No codes and it doesn't have any trouble starting when its warm. Any suggestions? Ultraguage is on its way but I Di have a scan tool. Thanks. Andy.
Old Feb 18, 2013 | 08:25 AM
IACV cleaned? Throttle butterfly cleaned (both with carb cleaner)?
Engine coolant sensor working (scanner shows logical coolant temp, not -40F, and that temp increases)?
Vac leak (which seals up when engine warms)?
MAF cleaned (with made for MAF cleaner, only when stone cold and key has not been in the ignition overnight)?
SAI system related?
Thinking that with all the underhood work another line may have cracked when moved (most do). Or connector not seated.
Old Feb 18, 2013 | 08:50 AM
mtrdrms's Avatar
Great checklist. Thanks. Gotta check iacv but the throttle body is clean. Coolant temp is good. Didn't do maf but I will and I don't have sai.
Old Feb 18, 2013 | 09:00 AM
Sounds like a IACV issue to me.
Old Feb 18, 2013 | 09:54 AM
Did you plug in the correct plug to the idle solenoid when putting it back together, there are 2 that look the same.
Old Feb 18, 2013 | 10:27 AM
mtrdrms's Avatar
I think so. What does the other go to?
Old Feb 19, 2013 | 08:51 AM
mtrdrms's Avatar
Turned out to be the iacv. I cleaned all the crud out with carb cleaner and cleaned the plug connection and refitted with dielectric grease. Problem solved.
mylittlepwny
Jun 9, 2013 07:46 PM
Disco_stu97
Nov 28, 2011 07:14 AM
Chrisinhouston
Nov 7, 2009 07:35 AM
D2 2003
Sep 26, 2008 07:35 PM
masterm
Apr 8, 2006 07:03 PM
