Head Gasket 2000 Disco II
Old Oct 30, 2011 | 10:52 PM
  #21
Drewak1's Avatar
we'll ... all back together but when I crank it over will not fire... no sputter.
Double checked the Elec and fuel connections.
anyone any ideas ?
Old Oct 30, 2011 | 11:03 PM
  #22
If starter turns, BCU is OK with trying to start, alarm is not immobilized. The inertia switch on firewall has a button on top, press it to reset. That switch keeps main relay from powering up all sensors, as well as enabling the fuel pump relay. The ECM will also want the crank position sensor to be operating.
File Type: pdf
File Type: pdf
Old Nov 3, 2011 | 08:23 PM
  #23
onewingman's Avatar
Oh, yeah!!! I gotta belt sander, and it's aLuLu too!!! I could get 30 off NO PROBLEMO!!! 2 funny...
Old Nov 22, 2011 | 09:58 AM
  #24
Drewak1's Avatar
Hey guys, Rover running great but have a huge oil leak from up in between the heads on top by the ignition coils. Sucks as it drips on the exhaust.
If anyone ever needs to mill there heads I have a fixture built for it now.
Also I hav e a CNC plasma cutter here and would like to build a front bumper for the D-2 Out of aluminum. Anyone have drawings ?
Thanks !
Old Nov 22, 2011 | 10:02 AM
  #25
Valley pan gasket has a bolt and a metal lip that clamps down in front and in rear of the gasket. Bolt is at the bottom of the valley.
Old Nov 23, 2011 | 08:11 AM
  #26
Drewak1's Avatar
bolted - YEs
Old Nov 23, 2011 | 08:23 AM
  #27
drowssap's Avatar
did you RTV the corners where the head, block and intake gasket meet?
Old Nov 24, 2011 | 09:15 AM
  #28
Drewak1's Avatar
no figured that out ;-(
thanks
Extinct
Jun 25, 2014 12:39 PM
mike111
Jun 2, 2014 08:58 AM
a-rod
Sep 21, 2013 09:33 PM
FlyingZebra34
Apr 25, 2013 08:04 AM
BaltimoreRover
Dec 2, 2011 11:24 AM
