Head gasket AGAIN?! Retorque head bolts? What can I do better?
Old Dec 28, 2017 | 08:20 AM
shanechevelle's Avatar
Are you positive it isn't the exhaust gasket? They do fail from time to time...any misfiring? Sluggishness?
Old Dec 28, 2017 | 09:30 AM
UncleDirtnap's Avatar
That’s what I was initially suspecting- but when I felt around the exhaust it was fine. I can feel the air from under the head gasket for bout 5 seconds before the engine gets to warm and you get burned
Old Dec 28, 2017 | 10:14 AM
Sixpack577's Avatar
Originally Posted by OffroadFrance
Bummer after doing everything right.
Check your cylinder block for flatness using a certified straight edge and a 0.002" feeler gauge. Also check that the points where the head bolts enter the block aren't 'raised' from tightening. When using head bolts always smear some oil lube on the threads first, just a smear only on the threads, to lube their entry during final torquing down.
https://www.youtube.com/watch?v=NKXY9Z285Lc
Just curious,
Steel bolts, aluminum threads.
Wouldn't anti-sieze be better than oil on the threads??
Old Jan 2, 2018 | 10:21 PM
Charlie_V's Avatar
Originally Posted by Sixpack577
Just curious,
That's what I use, too.
grandkodiak
Nov 2, 2015 11:25 PM
FlyingZebra34
Jun 30, 2013 08:30 AM
dancedisco
Feb 6, 2012 06:34 AM
mlfore
Apr 8, 2008 03:38 PM
rphotographer
Apr 26, 2007 09:03 PM
