Head gasket help
Old May 14, 2011 | 10:45 PM
Sunny side auto's Avatar
Default Head gasket help
So I did my head gaskets and had them re sufaced . I am getting a oil leak on both side now. It only leaks a very small amount . I put it on my shop rack and tried to see where it was coming from. I thinkmit might be the intake leaking Down the back but can't get it to leakmon the rack. I really hope the heads are not leaking . I find it hard to believe both sides would leak.
I did a ten minute wheelsnspinning on the rack and no leak. Only when I drive it's much but it has a small drip on the cat that stinks .
Old May 15, 2011 | 01:06 PM
You are going to have to clean the engine and then add some dye to the oil and drive for a couple of days and then look for the leak with a UV light.
Old May 15, 2011 | 03:00 PM
photocrimes's Avatar
Did you put the sealant in the corners of the valley pan gasket?
mike111
Jun 2, 2014 08:58 AM
FlyingZebra34
Apr 25, 2013 08:04 AM
dancedisco
Feb 6, 2012 06:34 AM
Absolutryn
May 2, 2007 06:00 PM
jcostello
Nov 2, 2006 10:28 PM
