Head gasket kit
Old May 14, 2022 | 10:55 AM
Blamo35's Avatar
Default Head gasket kit
Installing the head gasket kit from Atlantic British. Came with no paperwork or instructions. Can anyone tell me what these things are for and where they go? I assume the last set of orings are for the fuel injectors. But I can't figure out what these blue guys are.
Old May 14, 2022 | 10:59 AM
mollusc's Avatar
Valve stem seals.
Old May 14, 2022 | 11:52 AM
Blamo35's Avatar
Originally Posted by mollusc
Valve stem seals.
Well shoot, probably should of left those at the machine shop
Old May 14, 2022 | 11:58 AM
disco96sd's Avatar
Machine shop won't overlook that, SOP to replace - they might prefer to use their own seals - they will have a lot of experience on what are good seals so they might not have used those any way
Old May 15, 2022 | 05:45 AM
MSGGrunt's Avatar
What brand head gasket comes in the Atlantic British kit? I have read that Erling or Victor Reinz are the way to go. And to use a steel valley pan gasket and not the composite one. Are you using new stretch to yield bolts or stepping up to the ARP studs?
Old May 15, 2022 | 05:56 AM
Blamo35's Avatar
Elring gasket, and I got the ARP head studs
Old May 15, 2022 | 06:21 AM
MSGGrunt's Avatar
I will be going down this same path and I too will opt for the ARP studs. I am not necessarily convinced one has better clamping force than the other, but I like the idea of a stud in an aluminum head, especially if this is the 2nd or 3rd time the head has been off.
Old May 15, 2022 | 11:47 AM
Harvlr's Avatar
I’ve done my P38 and D2 and used new stretch bolts on both. The opinions on ARP or bolts seems to be divided so I went with the cheaper option. The one plus of the studs is you don’t need a 3’ bar.
Motorhead1
Feb 8, 2022 06:58 PM
Brandon318
Feb 3, 2022 10:48 AM
aemnky606
Apr 29, 2017 09:47 PM
Land McRoverface
Engine & Internal
Jan 12, 2017 07:17 PM
jofher007
Sep 17, 2012 01:44 PM
