Head Gasket kit....
re: order the upper intake manifold seperately
It is a metal gasket and may be re-usable under certain conditions. Perhaps that is why it is separate.
And when you first take off the top of the manifold, you will never have a time with easier access to the test valve for the fuel pump. Not saying you have a fuel pump problem, but a quick test gives you an idea of how you stand with that part of the truck.
Savanah, This is an excellent little piece of information that I think many, are unaware of. I know I should have checked first, but is there a write up section for doing ones head casket. If not I think there should be and this little gem needs to be on there.
And when you first take off the top of the manifold, you will never have a time with easier access to the test valve for the fuel pump. Not saying you have a fuel pump problem, but a quick test gives you an idea of how you stand with that part of the truck.[/QUOTE]
