Head Gasket kit....
Old Jan 10, 2012 | 05:36 PM
jrm123180's Avatar
Default Head Gasket kit....
does anyone know where I can find a description of what comes in the head gasket kir form Atlantic British? I know what most of them are, but there are a few i'm not too sure of.
Thanks!
Old Jan 10, 2012 | 07:25 PM
Just go click on their picture, it shows them all.
Have you ever done head gaskets before?
Old Jan 11, 2012 | 06:33 AM
drowssap's Avatar
with AB you will have to order the upper intake manifold seperately, i do not believe it comes in there kit. The also have kits with or with out head bolts, make sure you get the one with.
Old Jan 11, 2012 | 06:48 AM
re: order the upper intake manifold seperately
It is a metal gasket and may be re-usable under certain conditions. Perhaps that is why it is separate.
And when you first take off the top of the manifold, you will never have a time with easier access to the test valve for the fuel pump. Not saying you have a fuel pump problem, but a quick test gives you an idea of how you stand with that part of the truck.
Old Jan 11, 2012 | 08:11 AM
jeffh's Avatar
Savanah, This is an excellent little piece of information that I think many, are unaware of. I know I should have checked first, but is there a write up section for doing ones head casket. If not I think there should be and this little gem needs to be on there.
And when you first take off the top of the manifold, you will never have a time with easier access to the test valve for the fuel pump. Not saying you have a fuel pump problem, but a quick test gives you an idea of how you stand with that part of the truck.[/QUOTE]
brianb883
Jan 23, 2010 09:51 AM
devildog01
Oct 13, 2009 08:56 PM
usmc_mwroseberry
Feb 19, 2009 08:16 PM
jkid
Oct 27, 2008 04:39 PM
okdiscoguy
Dec 2, 2007 04:41 PM
