head gasket leak
Old Jul 23, 2012 | 10:08 AM
mylesman12's Avatar
Default head gasket leak
Finishing head gasket repair on 2004 Discovery 11, and bolted head down. Now there is water leaking, and I mean really leaking.
Don't know yet where leak is, but suspect air intake manifold. Used Permex to glue it down, and think we got it right.
Any thoughts???
Old Jul 23, 2012 | 10:11 AM
hose off to throttle body heater?
Old Jul 23, 2012 | 10:20 AM
drowssap's Avatar
probablly is the intake you used RTV on all four corners, is the water leaking from the front or rear? you probably want to go to your local autoparts store and borrow or rent a preasure tester, before you start tearing into it.
Old Jul 23, 2012 | 10:24 AM
X2 on tester - far better to pressure test than heat up the engine and you can use distilled water
Old Jul 23, 2012 | 10:34 AM
mylesman12's Avatar
You are correct. Discovered bad plastic hose.
Now putting in new thermostat and waiting for next challenge.
Many thanks Savannah-----by the way, is that where you live?
Old Jul 23, 2012 | 10:56 AM
actually 10 miles from Egypt, but you need a good map
mike111
Jun 2, 2014 08:58 AM
FlyingZebra34
Apr 25, 2013 08:04 AM
dancedisco
Feb 6, 2012 06:34 AM
stanigu
Jan 24, 2007 05:07 PM
jcostello
Nov 2, 2006 10:28 PM
