Head gasket leak, after having heads done. Help?
Old Apr 3, 2015 | 02:25 PM
  #51
drowssap's Avatar
Yes my thought is these things have been around a while now, and have been thru an owner or two. And probably an auction here or there. I would suspect any D2 with over a 100k could have possibly had head gaskets done once ,already.
Old Apr 3, 2015 | 03:24 PM
  #52
Motorhead1's Avatar
Wasnt their some welding done to one of the heads? Who knows how much the machine shop had to remove to get the surface flat again
This thread is a good reminder to anyone dropping off a set of heads to be milled at a machine shop to make sure the machinist checks the tolerances before any work to be done...
Old Apr 3, 2015 | 03:42 PM
  #53
drowssap's Avatar
Another thing to look for is if the shop has a blast furnace, if it doesnt then there only option is to grind aways.
there is a utube from a shop in ca. And you can tell y,this guy does everything possible using a furnace to make sure he is taking the only what he has too. Its a rover head too
Old Apr 3, 2015 | 05:18 PM
  #54
ls1morethanyou's Avatar
one head was welded and .010 removed from it, that head did not leak. the other head that has .008 removed did leak.
addeible
Jun 2, 2014 01:17 PM
GiGi La Luz Ramone
Aug 31, 2013 04:46 PM
glassman66
Jul 17, 2012 08:31 AM
JBEGIN
Jun 27, 2009 12:38 PM
