head gasket question
Old Mar 16, 2013 | 06:58 PM
TheyseemeRovin''s Avatar
If i a m looking at the same picture, That's definitely the hole for the dipstick tube.
Old Mar 16, 2013 | 09:01 PM
legendary's Avatar
cheers thanks for the time sorry for the confusion..im new to the rover world.,when i saw the gasket didnt cover the hole i wanted make sure of what it was before i put the head on and torqued it down thanks for the help.my camera is down again thanks for your time
Old Mar 17, 2013 | 01:34 AM
Better to ask questions and gain knowledge than act and regret later.....dont ask me how I know!!
Old Mar 17, 2013 | 03:28 AM
jfall's Avatar
Use common sense.
You need a #3 or #4 Phillips to get the oil dip stick tube mouinted back to the block.
If you loose that screw, it will be hard to replace.
Study how to tighten the head bolts carefully.
First time around on the bolts 15 foot pounds.
Next time around turn them all 90 degrees.
Third time around all 90 degrees again.
I used a pipe - a gas pipe actually from Mc Guckin Hardware in Boulder, CO to give me leverage.
Flickr: Landroverdude2's Photostream
Hopefully you put in Victor Reinz head gaskets..
Old Mar 17, 2013 | 07:43 AM
racerxnet's Avatar
Torque the bolts to 70 -75 ft lbs and forget them. Do it in 20 lbs increments until final torque is achieved. The screw to secure the dipstick to the valve cover is a plain old sheet metal screw. Nothing Ace Hardware does not carry. Probably 1/4 inch long.
MAK
Old Mar 17, 2013 | 08:42 AM
jfall's Avatar
Interesting on the 70 LBS.
He may not have ARP studs.
But, 70 LBS seems safer so you will not strip out the head bolt holes.
I know that the torque on the stretch bolts sure feels like more than 70 LBS when I have a pipe on a 1/4 inch ratchet extension.
Old Mar 18, 2013 | 10:08 AM
drowssap's Avatar
unless you are using an ARP Stud kit you should torque the heads the why the RAVE tells you too.
mike111
Jun 2, 2014 08:58 AM
FlyingZebra34
Apr 25, 2013 08:04 AM
dancedisco
Feb 6, 2012 06:34 AM
Tastang
Nov 30, 2007 05:47 PM
jcostello
Nov 2, 2006 10:28 PM
