Head Gasket Replacement
Old Nov 24, 2008 | 10:51 AM
kruth's Avatar
Default Head Gasket Replacement
After reading many posts about replacing head gaskets I still have a few questions. Here is a little bit of background about my problems: In August my engine overheated and I took it into a shop and they found the problem to be a loose connection that I was loosing coolant out of and I simply ran too low. They pressure tested everything and told me that my block and head gaskets were fine. However, recently i started hearing the whooshing water noise that people talk about underneath the dash and I became concerned. Sure enough my oil is foamy and I will be replacing the Head Gasket. I am a college student and cannot afford to have the work done so I will be towing the car home over Christmas break to try and do the work myself. So finally my question is, do I need to have the system pressure tested again to ensure that the block is not cracked? Also, how do I know if my heads have been warped from previously overheating?
My Disco had 118K miles on it and while I have everything torn down I was planning on doing some preventative maintenance, here's what I have on the list so far:
new water pump
resurface heads
timing chain
On my last major meltdown I had the plugs and wires replaced with heavy duty ones and a new serpentine belt installed. Thank You for any advice
Old Nov 24, 2008 | 02:58 PM
Default RE: Head Gasket Replacement
Send me your tele number and I'll be glad to help you get past this issue.
mikeljacobs@comcast.net
Old Nov 24, 2008 | 04:41 PM
You dont need to replace the timing chain.
bennyb43
Nov 28, 2015 04:01 PM
mike111
Jun 2, 2014 08:58 AM
FlyingZebra34
Apr 25, 2013 08:04 AM
dancedisco
Feb 6, 2012 06:34 AM
jcostello
Nov 2, 2006 10:28 PM
