Head gaskets
Old May 6, 2013 | 08:48 PM
aarons02's Avatar
Default Head gaskets
Hello. I received a quote from a local mechanic that has a good reputation. No more than $1,500 for complete head gasket repair. That includes all parts and head bolts.
He said they will get the heads machined, and the machine shop will do a pressure test. So that sounds like he will leave the valves alone if there are no issues. Should i have them completely gone through, or leave alone if there ok? I am guessing its a much bigger bill for new valve job and whatever else goes into a complete rebuild.
I wanted to see if there are any issues, or i should bring up to the mechanic before i give him the okay.
2002, Disco 2, 130,000 miles, 4.0 auto
Old May 6, 2013 | 08:55 PM
silar's Avatar
The quote I just got to get the heads cleaned, machined if necessary, valves lapped and seats ground, they'll install my new valve seals was right around $80 each head. This is just to get the heads prepped and I install the gaskets, heads, etc.. From what I've seen on this board, around $1500 is about the going price. The reason I brought up what I'm having done is to show that apparently lapping the valves and griding the seats shouldn't cost much more. I guess a lot of the cost is labor with the gaskets, bolts, etc going around $300 or so.. But I'm a Disco Noobie so what do I know!
Old May 6, 2013 | 09:41 PM
ZGPhoto's Avatar
$1500 is not a bad price if you can't do it yourself. I paid around $1k for everything and helped/took photos along the way.
Old May 7, 2013 | 02:13 PM
jfall's Avatar
$1500 is $1000 less then everyone else.
That is actually very reasonable!
RROJ
Mar 26, 2011 02:37 PM
drhunter
Mar 21, 2007 07:21 PM
rangerrick
Jan 25, 2007 05:10 PM
Steve O
Aug 25, 2006 04:26 PM
edthediscoman
Oct 5, 2005 01:58 PM
