Headlight assby and bulbs - 2003 Disco
Old Jul 31, 2013 | 06:15 PM
davecason's Avatar
Default Headlight assby and bulbs - 2003 Disco
Hi Gang,
I have a couple of questions:
I seem to be eating bulbs (the h7's) for the reg beams and the high beams at a fairly steady rate, like 1 every two months.... any ideas or suggestions as to why?
Number 2 - can you buy just the clear part of the headlight lens body?
I called my local rover specialist shop and of course each headlight unit for the left and right sides are worth $400 each - that seems like an expensive way to clean up the clear lens part since its just got the usual pitting and yellowing some cars get .....
I am trying that headlight lens restorer stuff but it is pretty slow going polishing the clear lensand it does look like it might come off the whole lens body - just wondering ....
Cheers'
Dave
Old Jul 31, 2013 | 07:16 PM
dgi 07's Avatar
Are you touching the bulbs on install? The glass part?
Old Jul 31, 2013 | 09:19 PM
davecason's Avatar
Default mitts off
Oh heck no, even I know better than that ! (grin)
Naw, it's not right away just that in a year I'll replace like 8-10 bulbs and that's
a pretty even mix between left and right and low and high beams ....
I'm thinking over voltage but that's just crazy talk ?!!? Isn't it ?
Cheers'
Dave
Old Jul 31, 2013 | 09:48 PM
dgi 07's Avatar
Check your grounds. Fuses, relays, and voltage across battery with the vehicle running. Make sure connectors for bulbs aren't green.
Old Aug 1, 2013 | 06:36 AM
drowssap's Avatar
x2 on grounds
Old Aug 1, 2013 | 09:31 AM
dusty1's Avatar
x2 on looking for green. i have a work truck that started eating bulbs as well. turns out, i just needed to clean the sockets out with a little scraper and brush, corrosion had accumulated. problem solved
Old Aug 11, 2013 | 03:14 PM
davecason's Avatar
Default OK, I'll check em - thanks !
OK,
Thanks for the tips guys - I'll check he connectors for corrosion and see what happens.
I took a buffer and some of that compound and they came up pretty decent too!
Cheers'
Dave
Old Aug 12, 2013 | 10:53 AM
Snafu / Disco Fries's Avatar
Make sure the previous owner didn't solve a problem with a short by bypassing the fuse/relay or by putting in a fuse/relay that is way too big.
Old Aug 12, 2013 | 11:51 AM
G150driver's Avatar
Originally Posted by davecason
OK,
Cheers'
Dave
Which compound did you use? I've got one lens on my '04 getting kinda cloudy. Thanks!
andrewcloy
Sep 14, 2007 11:31 AM
andrewcloy
Sep 7, 2007 07:23 AM
jdelp
Aug 23, 2007 03:35 PM
johnnybob06
Jul 24, 2007 07:43 PM
fire1427
Jun 14, 2007 09:52 PM
