Headlight problem, one shines normal the other just shows parking lights
When I turn on my headlights the right one will turn on completely but then the left side will just show the parking lights (i.e. if you turn the light switch just one click rather than two.) where the amber turn signal light is illuminated about 50% and the headlights are not bright at all (just the dull shine of the parking light.)
So my question is: Is this an electrical issue, or do I just simply need to replace the headlight bulb? And if it is an electrical issue how can I go about finding and fixing it? If it is a bulb issue, how do I replace the bulb? Does the fact that I have a brush guard make it difficult to get to?
Any feedback would be greatly appreciated.
on
Just so you know, the same holds true for your rear lights, check them once a year and replace in pairs if you see bulbs that are starting to turn black. Also if you want a little brighter light, replace your old bulbs with long life type bulbs which not only last longer but are brighter.
Snafu / Disco Fries
03-11-2021 06:39 PM
BostonLR3
10-10-2015 10:58 PM
tibyABv6
12-18-2012 10:09 PM
