Headliner upgrade
Old Apr 20, 2019 | 04:23 PM
  #21
cvhyatt's Avatar
Looks fantastic!!
Old Apr 21, 2019 | 09:26 AM
  #22
za105's Avatar
Thanks mollusc!
Old Apr 22, 2019 | 11:13 AM
  #23
losinov's Avatar
Looks great! $100 sounds like a good deal for reupholstering the headliner. Did you follow a DIY that helped you with removing the panels and trim in order to pull the headliner?
Just applied the same product to the doors in my Prius and am really pleased with the result.
HIGHLY recommend this roller tool from amazon HIGHLY recommend this roller tool from amazon
. I also used
the joint tape the joint tape
to seal up most of the edges on my doors. You can cut the tape lengthwise to really make it last!
By the way, with sound deadening you don't need to cover 100% of the surface areas to get a good result. Just the major patches.
Old Apr 22, 2019 | 01:55 PM
  #24
NewToTheTwo's Avatar
Thats because this product isnt "sound deadening" material, its vibration deadening like Dynamat - been misused since its inception and still is.
I've used the exact same Noico and only applied it by itself, but in reality, a high density foam "sound deadening" material should be placed on top of it for best results.
Old Feb 12, 2024 | 09:05 AM
  #25
Tstewart1's Avatar
What shop here in phoenix did it for you?
Old Feb 16, 2024 | 02:52 PM
  #26
HopeItsNotAMoneyPit's Avatar
Necro-post
Did you find that the sound deadening material actually reduced cabin temperatures? I live in a very hot place and am considering cooling options, to include adding insulation between the headliner and roof.
Old Feb 16, 2024 | 04:21 PM
  #27
Discorama's Avatar
It helps a little bit in summer, but not much. I lined my roof with
this this
stuff mainly for insulation in winter. Most heat gets through the windows anyway, if you don't cover them, it doesn't make a big difference. I have covers for all windows because I sleep in the car in winter. This plus the roof insulation keeps me warm without a heater in a good sleeping bag (I experienced 10 deg. F outside recently in the morning).
One note about that foam with reflective foil on top: It doesn't improve insulation if you glue it onto a surface and cover it with other stuff. It needs a few inches of air in between the reflective foil and a heat source in order to work as a heat barrier. The reflective foil reflects heat radiation back to where it came from when there is an air gap. Otherwise it just works as a heat conductor. Using this kind of material makes more sense if you glue it on top of the head liner.
MATT04
Mar 15, 2022 05:14 PM
Jeff Blake
May 16, 2018 01:50 AM
StrangeRover
13
Apr 4, 2014 03:14 PM
suzukisam967m
Oct 8, 2012 10:25 PM
BajaXJ92
May 8, 2012 04:07 PM
