Heat and head gaskets
Old Dec 28, 2014 | 10:54 AM
film842's Avatar
Default Heat and head gaskets
Do head gaskets go south only on an occasion of the engine overheating...or...can they blow just from accumulated use?
I'm wondering if I can get through the winter months by closely monitoring engine temps which would allow me to preemptively replace them in the spring.
If it's a random occurrence, then I'll have to get it pretty soon.
2002 Disco/140k.
Old Dec 28, 2014 | 11:55 AM
Alex_M's Avatar
Yes, it's mostly random. They start to go little by little until they just get too bad. I drove almost a year with mine leaking and I just continued to top off the coolant until I could afford to have them switched.
Old Dec 28, 2014 | 01:01 PM
dusty1's Avatar
Yep they deteriorate ...100k ish intervals usually
You can greatly speed the process or even wipe them out all at once with 1 or more overheating episodes
Old Dec 29, 2014 | 12:01 AM
Dave03S's Avatar
If you pay attention to your coolant levels and temps you will know when you need to start paying attention to the HG. Early sign is a loss of coolant in the overflow tank. Any level change means something is up. Not necessarily HG. Typical HG external leak is on firewall side of heads. Could also go internal... Then you'd have contaminated oil issues and misfire codes.
Preemptive replacement is not necessary, You'll know when it's time if you pay attention on a regular basis.
As mentioned you can keep topping up the overflow tank to prevent overheating or air getting into the system for quite a while as long as you keep a close eye on all systems.
Old Dec 29, 2014 | 10:36 AM
film842's Avatar
Thanks for the advice. That gives me a plan I can follow. It hasn't been my practice in the past to check either oil levels or coolant levels very often since
the old girl hasn't ever leaked much at all.
Now however, I have a good reason to pop the hood and check it out. Thanks again.
Old Dec 29, 2014 | 11:23 AM
binvanna's Avatar
I think there's three contributing factors. "Normal wear," in other words they will eventually blow out as time and wear accumulates. They will also blow out sooner if the engine overheats. The third reason they blow out is because of a crack in the cylinder behind the liner that blows steam up the side of the liner and erodes the head gasket. Coolant loss from this issue is a major cause of overheating which itself will shorten the life of the head gasket, but if the crack has developed badly enough the head gasket will only live a very short life even without any overheating or many miles at all. The solution is flanged or "top-hat" liners. But there are some engines more likely to be affected by this issue than others.
jmason
Nov 17, 2013 06:39 AM
RROJ
Mar 26, 2011 02:37 PM
drhunter
Mar 21, 2007 07:21 PM
Steve O
Aug 25, 2006 04:26 PM
edthediscoman
Oct 5, 2005 01:58 PM
