Heat Problems
Old Jan 6, 2009 | 08:56 PM
darkstar2002c's Avatar
5th Gear
Default Heat Problems
A few months ago I bought a used Land Rover Discovery II - year is 2000, just over 125k miles.
It has a few minor issues - and two major issues (at least to me) one of which developed only two days ago.
I have had no problems with AC or heat since I bought the vehicle. However, two days ago when I started the car and let it warm up for about 10 minutes and came to get in it was still cold. I had to get to work so I suffered through it on the way to work. It was pretty cold that day so I assumed maybe that was why. Although, in negative 6 degree weather a few weeks ago I didn't have this problem, so I was a bit confused since it was 10 degrees out.
Anyways, today it was about 40 degrees outside. However, when running the heat at any warm/hot temperature the car would not warm up. Even with the temperature settings maxed out it was blowing cold air.
The only exception it seems is with a lot of engine revving and then the car will blow warm air for a few minutes although it doesn't come out very strong.
What things can I start checking?
I am a new land rover owner - this is my first so I am not accustom to all the quirks yet.
What should be checked first? What things can I try doing to resolve this problem? I have found a few ideas online and thought about checking the engine coolant. Could this be the cause of the problem?
Thanks for any help and ideas you can provide!
I have absolutely fallen in love with this vehicle. Once I resolve this issue I will post a question about my second concern and hopefully once that is resolved I can enjoy the vehicle even more.
Old Jan 6, 2009 | 09:19 PM
Default RE: Heat Problems
Start by checking your coolant level, I suspect that it is empty.
DO NOT overheat the engine, if you do you will be buying a new one. Aluminum engines do not take overheating well.
Once you get the coolant filled take it to a shop and have them pressure test the cooling system.
Old Jan 6, 2009 | 11:24 PM
5th Gear
Thanks - that seems to have solved the problem.
Now, onto another issue. I am wondering if all of my dashboard lights are working...
Most come on when I start the car - SRS, Seat belt, etc.
However, if I keep my seat belt off the light doesn't stay on - is that normal?
Also, if I push the button for the downhill descent assist I hear a few short beeps. But, the downhill descent light does not light. Is this normal? Does it only light when it is being used but not necessarily when I enable it?
I just want to make sure all the lights are functioning.
It worries me that my coolant was low almost completely out and I had no warning. It never overheated but maybe that's because it wasn't very warm out and I wasn't driving very far.
One more question the passenger seat warmers work very well. However, the drivers side seat warmers do not work very well, if at all. I can't tell for sure - sometimes they seem a little warm but I think it may just be the heat. Is there something I can check into to see if something is unplugged or a fuse is blown? I assume that both seat warmers use the same fuse but maybe that is not the case.
Thanks again!
Old Jan 7, 2009 | 11:15 AM
If you didn't bleed your coolant system when adding fluid, the problem will probably come back.
PM me with your tele number and I will call you and walk you thru what to do.
Frank4
Mar 21, 2014 05:21 AM
jmason
Nov 17, 2013 06:39 AM
Johnsy
Nov 26, 2006 06:07 AM
fjfarias
Dec 12, 2005 05:43 PM
asmcmillin
Jan 23, 2005 01:18 AM
