heated seats !
RE: heated seats !
I looked under the seat of my D1 trying to solve the same problem. I found 4 relays corresponding to the 4 motors for the power seats. I never found a relay for the heated seats. Most likely the problem is that the heating element has an open section it and no continuity in the circuit causing it not to work. It is common for the heating elements in seats to break on the side closest to the door where your butt hits first as you enter. I actually pulled the seat cover on the driver seat in a Saab I had and soldered it back together and got it working. I haven't dug that deep into the Rover seat yet to see if that fix will work but I can't see why it wouldn't. Just make sure to wrap the repaired solder joint with electrical tape or similar to keep the seat foam from catching fire.
RE: heated seats ! and other electrical issues
in addition to my heated seats not getting warm the compass in my rear view mirror is out.
is there a fuse they have in common.
no other issues that i can remember - the dome lights, dash lights, radio, windows, and climate control all work.
thanks
jaynes
thanks
jaynes
booper169
11-09-2010 09:10 AM
tophetec
12-02-2006 01:03 PM
sydneysport
10-01-2006 09:18 PM
sydneysport
09-24-2006 11:33 AM
